Question electrolytic capacitor from 1990`s
This topic is closed.
  • gamer87
    Banned
    • Sep 2021
    • 12
    • usa
    I have electronic devices from 1990 and I know that these devices that have not been used for a long time cause faults and depolarization in the electrolytic capacitors, is it necessary to use these devices in the interval of 1x a month to preserve the electrolytic capacitors from failing due to disuse? are used electrolytic capacitors manufactured since 1990 and assembled in electronic circuit
  • gamer87
    Banned
    • Sep 2021
    • 12
    • usa
    Re: Question electrolytic capacitor
      • 21936
      Originally posted by gamer87
      Can you be a bit more specific about the types of devices,can you post pictures and details of the capacitors in question .
      • gamer87
        Banned
        • Sep 2021
        • 12
        • usa
        Re: Question electrolytic capacitor from 1990`s
        Snes, PS2 Slim 90000, CRT TV and general electronics
        • gamer87
          Banned
          • Sep 2021
          • 12
          • usa
            • 31256
            consoles are probably fine.
            the tv is a differrent story.
            electrolytic capacitors fail with a combination of time and HEAT or high-voltage.
            consoles like you listed dont really cook themselves.
            i'v not seen in a ps2 slim, but it's probably all smd stuff - not something to work on if you dont have to.
            if it still works fine and you cant see or smell any leakage then leave alone when it comes to smd caps.
            you stand a reasonable chance of damaging the board trying to remove them.
            • gamer87
              Banned
              • Sep 2021
              • 12
              • usa
              what worst brand of electrolytic capacitor?
                • 31256
                it doesnt work like that.
                even shit caps can run for decades if they arent being cooked.
                there is a thread for bad vs good caps here if you want to look through hundreds of posts!
                • gamer87
                  Banned
                  • Sep 2021
                  • 12
                  • usa
                  i use electronics device manufacturer 90 years all month?
                  • brethin
                    • Dec 2008
                    • 1907
                    You not smart, please stop speaking, you not know anything you ask and have no knowledge to teach you. robot!☹️
                    • gamer87
                      Banned
                      • Sep 2021
                      • 12
                      • usa
                      They told me that if I don't use these devices 1x a month their electrolytic capacitors will fail and depolarize
                      • PeteS in CA
                        • Aug 2005
                        • 3582
                        • USA, Unsure of Planet
                        They told me that if I don't use these devices 1x a month their electrolytic capacitors will fail and depoarize
                        Only posting when sober sometimes works, too.
                        PeteS in CA
                        • Heihachi_73
                          • Jun 2012
                          • 713
                          Older consoles e.g. 70s/80s/90s rarely ever have capacitor problems, original Xbox supercap aside. I'd only recap the TV if the picture is looking like crap already. You're more likely to have an old console stop working properly due to corroded traces, and that's even easier to fix. I have a Tekken 3 arcade PCB (which is basically a PlayStation 1 on steroids) and the caps are still fine - the thing was probably running 24/7/365 for well over a decade before I ended up with it.
                          The thing about caps dying from disuse really only happened with vintage (read: antique) electronics e.g. paper caps from the 1930s. Of course, crap caps can also fail just by looking at them (and crappy AAA batteries in remotes, cough, Duracell, cough - measures 1.51V but leaking like a sieve), but consoles rarely ever cheap out on caps.
                          • gamer87
                            Banned
                            • Sep 2021
                            • 12
                            • usa
                            No recommendations for my specific case?
                            • AleXis6
                              • Feb 2021
                              • 69
                              • Belarus
                              check and replace bad capacitors.
                              • gamer87
                                Banned
                                • Sep 2021
                                • 12
                                • usa
                                The reform of the electrolytic capacitor will need to be carried out periodically but I have doubts if this reform can be done by plugging the electronic device into the wall socket, I have electronic devices from the early 90's eg Snes consoles, PS2 Slim TVs CRT
                                Does the maximum time to carry out this reform depend on the age and brand of the electrolytic capacitor? in the worst case (brand and capacitor from the beginning of the 90s) what is the minimum time for reform?
                                • PeteS in CA
                                  • Aug 2005
                                  • 3582
                                  You might find the initial post in this thread helpful, https://www.badcaps.net/forum/showthread.php?t=50530 .
                                  PeteS in CA
                                  • gamer87
                                    Banned
                                    • Sep 2021
                                    • 12
                                    • usa
                                    any real recommendations for me to use my electronic devices at intervals of time without compromising and failing electrolytic capacitors? are devices from the early 90's
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      When you want to play/use them.
                                      • gamer87
                                        Banned
                                        • Sep 2021
                                        • 12
                                        • usa
                                        I can't use it every day, they're devices from my collection
                                        • MORETTIGIAN
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          Procedure performed:
                                          - Removed backplate
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          09-18-2025, 12:14 PM
                                        • cloudff7
                                          Electrolytic capacitor leak in storage?
                                          by cloudff7
                                          there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
                                          07-22-2024, 06:27 AM
                                        • AleXis6
                                          Manufacturing Date of Electrolytic capacitor
                                          by AleXis6
                                          Guys. could you help me please to decode some codes of main capacitor's producers.
                                          I would like to know the manufacturing date.
                                          Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
                                          If I understood correctly:
                                          1. Nichicons marks date of production as (see the attached pictures) H2116
                                          I don't understand the meaning of first letter - may be it is code of factory.
                                          21 -year
                                          16 week
                                          I bought this capacitor recently.
                                          another one-
                                          2....
                                          10-11-2021, 02:20 PM
                                        • Prolog
                                          by Prolog
                                          12-01-2024, 08:27 PM
                                        • beogeek
                                          Need replacement advice for surface mount electrolytic capacitor
                                          by beogeek
                                          I have a faulty monitor, the surface mount electrolytic capacitor 33uF 100V needs to be replaced, now I can't seem to source them locally, so my question is can I replace it with a through-hole electrolytic capacitor of the same value? Or has someone got a better suggestion?
                                          Cheerio...
                                          03-17-2022, 01:43 PM
